Home > Puma (Tdci) > Coolant level alarm.
andy63
After a recent near miss where I'd lost a fair bit coolant with a dodgy fitted clip I thought I'd fit an alarm..
Got one that fits into the top hose, and fitting is straight fwd.. The fiddly bit is running the wires..
It a audible wit a visual flashing led as well... Facility to power a relay when it actuated.. I didn't use that..
Its a simple float type on off switch, and has a 20sec delay before alarming..
The highest point on my top hose is close to a 90deg bend and I did wonder if turbulence might be an issue but went ahead and fitted it there..
On the test drive I found out it works🙈🤣
As I'd managed not to tighten a clip..
About 3 miles into the drive it alarmed, and after a bit swearing and muttering I thankfully pulled in to find coolant all over..
You can see the offending llip in the photo I took of the install🙄😩..
While I had the coolant drained I fitted an alloy expansion tank as well👍
I'll see how it all goes👍
Post #1030026 1st Apr 2024 9:54am
geobloke
Love the expansion tank and red hoses. Very smart.
What are those hose buffers you you have fitted. Like those too... Thumbs Up
Post #1030032 1st Apr 2024 10:52am
andy63
Hi G... The buffers are standard fit on the hoses as far as I know... Certainly wasn't me who put them on but they prevent the hoses rubbing were there is contact, and it's tight down that side with a right nest if hoses😩
The one fitted to the top hose where I put the sensor was the reason for me little mishap.. I had actually installed it well enough but realised I'd left the rubber buffer off so undid that clip and fitted the buffer... But forgot to tighten the clip again😩
Post #1030034 1st Apr 2024 11:02am
