Home > Td5 > Electric Windows Switch Wiring
110Matty
Hello all,
PO fitted aftermarket electric windows, which work fine. I want to change the switches to genuine and wondered if anyone knew the pin outs on these switches currently fitted.
They are marked as AnSor Brevet and all i can get on google is from VW forums, but no pin outs or detailed information. Obviously LR wiring diagrams won't help.
I'm guessing two are to the motor (? blue and black?), illumination live (smaller red?), ground (joined browns) and ignition +12v (joined larger reds?).
Any help much appreciated as usual.
Post #1029597 28th Mar 2024 2:56pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, you're going to need to do some basic continuity checks with a multi meter and work out which wires go where, which have power and which is an earth. As log as you have two wires running to each motor and you know which is up and which is down you can make a start on the OEM switches. If you have the switches you need two of these -
https://www.mobilecentre.co.uk/white-6-way...nector-jlr
And they are wired as follows -
The RO wire is the illumination for the switch, take that from a neighbouring switch or if you're being really good take them from the header where all the other RO wires are connected., you can get the connectors here -
https://www.ebay.co.uk/itm/161470778271?ep...XQBuNQ7Dfh
In the most basic of terms the OE switch, when pressed, allows current to flow to the motor on one of the wires and creates a path to earth (via the switch) on the other wire. So - power to the switch, earth for the switch, a wire for up to the door, a wire for down to the door and a wire for the illumination.
Post #1029611 28th Mar 2024 4:25pm
Penfold_6290
Post #1029612 28th Mar 2024 4:28pm
110Matty
thank you @penfold_6290 - yes I have purchased those connectors and also the genuine dash switches. I was hoping to use the wiring already done by the previous owner (i.e. take the wires from the existing switch and put them in the correct order into the new white 6 pin ones mentioned and plug into new genuine dash switches). I guess I'll have to get my multimeter out to try and suss out the existing wires, or start again using LR original coloured wiring, following the diagrams kindly provided. If I knew the pin out of the existing switch, it would make things much easier, I just can't seem to find it. Embarassed
Post #1029617 28th Mar 2024 4:37pm
Penfold_6290
Hiya, i was editing and adding detail when your reply came in so maybe take another look at my reply. You could do this without taking the door off, with a meter check the back of the switch to see which wire is live when the window down command is given, which is live when the window up command is given. You can then relate the wire colour to the correct pin on the switch based on the wiring diagrams. No need to run new wires...wait until they eventually break in half in the rubber trunking between door and bulkhead (which they will) and do it then!
Post #1029621 28th Mar 2024 4:41pm
110Matty
Hi, yeah it was weird, when I initially replied you hadn't mentioned the multimeter, which is why I said I'd have to get mine out. I've seen all of your post now, very helpful thank you. I'll report back with any progress Thumbs Up
Post #1029623 28th Mar 2024 4:47pm
110Matty
I found this also, for the pin outs on the OE switch / connector?
Stupid question - i take it the illumination wire only goes to +12v when the light stalk is activated (i.e any lights switched on?) Embarassed
Post #1029625 28th Mar 2024 4:54pm
110Matty
Cheers mate, which part of Dorset are you in? - i'm near Somerton / Yeovil. I'm looking for someone to look after the oily bits of my maintenance / repair and decent specialists in Somerset are few and far between it seems, either that or they have long waiting lists - good for them and current clients, less good for the likes of me. Sad
Post #1029628 28th Mar 2024 4:58pm
Penfold_6290
That's the same explanation as the LR electrical library, your fun challange is to work out which lift wire is which!
The illumination wire can go to a neighbouring switch if needs be. All the switches will have a red wire with an orange stripe, this is the illumination wire that is live when the side lights are on. All those red/orange wires meet at a header joint somewhere behind the radio, trace one back and see if you can find it. You could tap into the header joint, it is basically a plastic unit which accommodates many wires, one RO wire will supply 12v when the sidelights are on and then the header provides a common connection for all the guage and switch illumination on the truck
Post #1029629 28th Mar 2024 4:59pm
110Matty
Brilliant, thanks.
Post #1029630 28th Mar 2024 5:00pm
Penfold_6290
Post #1029633 28th Mar 2024 5:30pm
110Matty
Fixed - sort of
Hello,
Just an update, I now have the windows working from the OE switches Thumbs Up
However….. the PO that fitted the aftermarket switches cut the dash because they are slightly larger switch bodies than the OE ones. It means the OE ones now won’t click in the dash Embarassed
I don’t really want to spend £150 on a replacement dash. Do you reckon I could modify a blank switch panel and fix it (glue/screw) over the cut hole so the OE switches fit? Is there another option?
Post #1029770 29th Mar 2024 7:21pm
PaulMc
The switch plate you've pictured, is for the 'Lucas' switches down by your right knee, the electric windows switches won't fit into that.
The Freelander-1 had window switch escutcheons on their rear door window switches.
FVN000010LNF and FVN000020LNF - in Ash Grey
FVN000020PUY - in Black
The MGF centre console facia FJM100640PMA has 2 x window switch cutouts -
https://rimmerbros.com/Item--i-FJM100640PMA
It is the same Black as the Defender centre facia - 'PMA'
Although the MGF windows switches are a different part number to the Defender switches, they use the same bodies and switch fronts -
. Paul.
Post #1029773 29th Mar 2024 7:42pm
110Matty
Thanks Paul. I’m not sure these fill fit into the aperture in the dash? I have a discovery 2 switch panel (that I took the OE switches from) and I might be able to jigsaw out ‘an escutcheon’ that I could fix in. I’m a bit surprised there isn’t an escutcheon plate available that allows early TD5’s to add electric windows with OE switches (without having the later full dash upgrade). I’ve seen the carling switch ones and as you pointed out, the one for the Lucas switches I wrongly thought would be ideal.
Failing that I might cut a couple out of sheet metal, paint it and glue in. Would be 99% hidden by the switch.
And failing that, pay a fortune for a replacement dash panel. 🤬
Post #1029786 29th Mar 2024 10:16pm
PaulMc
Have a read through this thread -
https://www.defender2.net/forum/topic49880.html
Further on in the thread, Andy has said that window switch surrounds are possible. Paul.
Post #1029787 29th Mar 2024 10:31pm
