![]() | Home > Maintenance & Modifications > Diff oil |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2415 ![]() ![]() ![]() |
That is the correct way to do it.
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 176 ![]() ![]() |
great thanks ... Same with the transfer box aswell?
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
Yes, also transfer box.
If you have Td5 or earlier, also the main gearbox is fill to spill. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 237 ![]() ![]() ![]() |
Transfer box and gear box for a Puma are not fill to spill.
Transfer box 2.3 litres required. Gear box 2.4 litres required. |
An interesting discussion on transfer box oil capacity vs level on this thread: https://www.defender2.net/forum/topic56771-15.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Without wanting to start another new thread.. the
Transfer box breather....found it ... can I just pull the pipe off to check it's clear .... Last edited by Naycrx on 24th Mar 2024 7:12am. Edited 1 time in total |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 241 ![]() ![]() |
Make sure you remove the fill plug before the drain plug, not only does it help the oil drain smoothly but you don’t want to drop the oil and then find the filler is seized.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
^^^^ This, and it’s also a good time to fit magnetic diff plugs if not already fitted too. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
