![]() | Home > In Car Electronics > WTF are all these wires and connectors? |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
Whilst rooting around the engine bay on 'other matters', I came across the following selection of connectors and wiring stuffed under the driver's side wing. Does anyone know what they are all for? Should the connectors be connected to anything? Are they LR surplus? Previous owner have some mighty lighting rig etc? Any ideas?
![]() Click image to enlarge ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1355 ![]() ![]() ![]() |
The standard loom contains connectors for buttons etc that are maybe not fitted on your car, like adjustable headlights, alarm, speakers, etc.
I find the easiest way to identify a connector is to look at the wire colours and find it back at https://www.lrworkshop.com/ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6720 ![]() ![]() ![]() |
Most of them are Wabco ABS system connectors.
Looks like you have an ABS equipped bulkhead loom but no ABS fitted? You'll have 3 unused connectors under the RH seat as well, near the fuse box under there. The black with 2 wires would be the condensor fan connector I believe, wire colours should be BLACK and BLACK/BROWN. I assume you don't have air con (although from photos you have an AC nose)? ![]() ![]() |
