Home > Puma (Tdci) > Turn the key, momentary delay before starting.
Bluest
As the title really…. Jumped in tonight, waited for the glow plug light to go out, turned key start then nothing for maybe a second, but then sprung into life as normal. Any ideas? 2007 110 TDCi Station Wagon XS
Post #1022840 28th Jan 2024 8:05pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Sticking contact/relay? Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1022852 28th Jan 2024 8:55pm
Starter getting a bit tired, I have had a similar event happen a few times but seems to still keep going.
I wouldn’t worry too much unless it stops starting all together. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022854 28th Jan 2024 8:58pm
Bluest
Not sure, could be I guess. Are they any that could be replaced as a matter of course for not much money? 2007 110 TDCi Station Wagon XS
Post #1022863 28th Jan 2024 9:31pm
Bluest
Hope it lives on. I read changing the starter is a ball ache. 2007 110 TDCi Station Wagon XS
Post #1022864 28th Jan 2024 9:32pm
Most things to change on a Puma are a pain. Laughing
Any time I’ve had any issue, it’s always been a loose ground or battery clamp(s) loose. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022865 28th Jan 2024 9:37pm
DAZ110
Immobiliser ?
Post #1022899 29th Jan 2024 1:14pm
Bluest
Could be, maybe the key wasn't detected momentarily? I don't know how I would test for that though. 2007 110 TDCi Station Wagon XS
Post #1022913 29th Jan 2024 2:40pm
HardCharger
Ignition switch signaling it's about to go kaputt?
Post #1022986 30th Jan 2024 3:46am
Fob battery getting low can cause odd things to happen. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1022997 30th Jan 2024 10:19am
Bluest
Ignition switch had crossed my mind. I don't think it's low battery as it sits on a Ctek for 99% of the time, plus when it did start to turn over the starter sounded lively. 2007 110 TDCi Station Wagon XS
Post #1023001 30th Jan 2024 10:45am
I meant key fob battery the alarm plip one. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1023013 30th Jan 2024 2:44pm
dannyragsdale
Papau New Guinea 2012 Defender 110 Puma 2.2 HT Fuji White
I had this happening to me when my starter was on its way out. Lasted for about 6 months before it finally quit on me. I generally noticed it getting worse after the vehicle was hot. If i had to make a quick stop and turned it off, it would sometimes worry me that it wouldn't start back up. Replacing the starter is a pain and I even had it on a lift.
Post #1023514 4th Feb 2024 9:44am
BrickBox
Replacing the starter motor isn’t as bad as you might think.
Removing a few coolant hoses from the top to give you eyes on the starter and then undoing it from underneath is the best approach. And definitely get some coolant clamp pliers.
https://www.screwfix.com/p/silverline-flex...lsrc=aw.ds 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1023517 4th Feb 2024 10:33am
And disconnect the battery first. To prevent any fireworks Laughing 🎆🎇 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1023595 4th Feb 2024 10:22pm
