![]() | Home > Technical > Fuel sender wires |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
Nominally, the yellow/purple is Sensor Signal, green/orange is Sensor Ground.
With these senders, the centre tab is normally ground, and the forward-most tab is signal. The (unused) 3rd tab (rear) is for low fuel light, which you won't be using. ![]() ![]() |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551 ![]() ![]() ![]() |
Awesome, Thanks Martin
![]() Just to make sure so green/orange tab #2 yellow/purple #3 ![]() Shane |
In theory yes
Thanks Martin, sure we will give it a go
gotta give you a shout regards buying the hazard light extender Shane |
