![]() | Home > Maintenance & Modifications > Chequer plate question |
Having had one corner of our "other" car shaved off recently, I have been thinking about getting chequer plate on the rear corners of the Defender (a Puma).
I can't find any decent pictures so please can someone tell me how far it reaches underneath the fold? There are the two small bolts (support and mudflap) which I guess will have to go through the drilled chequer? I have also bought Entreq mudflap strengtheners (not yet fitted) that I guess would have to go back? Any advice much appreciated. Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Actually, don't worry - I ordered the chequer anyway so I'll just have to deal with it when it arrives
![]() Sorry - crisis of faith ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
It's a great suggestion but unfortunately I already have a rear bumper/step/towbar thingy on the back. Sorry - should have made that clear from the start.
IMO it's a bit of a stupid LR design because it doesn't come round the corners enough to protect them (why?) but it's also got my parking sensors in it so I don't really want to change it. I figured the chequer plate was the best "soft solution" I could do against repeated side scrapes from all the witless 80+ year olds in their Mercs around where we live (especially in hospital car parks ![]() Thanks for the good advice though - I would certainly follow it if not for the junk already on the back ![]() Cheers Matt p.s. It's also entirely possible that bumperettes are not type-approved here in good old Deutschland - a lot of external accessories aren't ![]() But shout it at them in German because life is also terrifying and confusing... |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Peter at Nakantanenga sell rear bumperettes, so I will assume he has checked out the type approval status in Germany.
Looking at the photos on his site, there does not appear to be as much as a 'scoop' which goes under the body work. That could be an artefact of the photo or a different design to what I am used to. On our Puma we have aftermarket reversing sensors fitted. These are attached to the underside of the bumperettes step. Brendan |
I deliberately ordered these before: http://www.ebay.de/itm/370281047024?ssPage...1439.l2649 as they go right under (or so it says). I can always send them back if they're crap. I'll check out the Nak. bumperettes anyway in case I change my mind. Thanks again Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
I'd be careful of using chequer plate as protection against anything more than slight impact.
It's only really any good as protection against weathering/footprints etc. Those shown above might stop the lower part of the wing being damaged, but I suspect all that'd happen is the wing would crease higher up instead, along the top edge of the chequer plate,(in the case of the 110 pictured that'd be right by the filler cap aperture) Genuine protection really needs to fend off objects before they make contact with the thin body panels, and that usually means bumperettes, attached to part of the chassis. |
Thanks - it's purposes are to stop old men and women rubbing up against me (yeeucchhh) in their euroboxes (it happens a lot round here- I live in a "retirement area") - not serious impacts. Also to strengthen the mudflap and support bracket, act as a repair (my son has dented it with his bike) and ... the wife likes the look of it! I'm stuck with the slightly inadequate LR bumper (towbar, reversing sensors etc.) for now but we'll see... Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Been fine so far in our insanely tight Tesco car park. In fact I've done a trolley test and can't find an angle where it's not protected.
I have reversing sensors - they are called my eyes and if they fail me, my ears. WHACK! Ooh look, my tow bar had a small mark on it. Shame that car it has interacted with has folded in half. ![]() ...I'm joking... Mostly... Defender 110XS SW gone... now VW California 180 4 Motion. |
I have chequer plate on the bonnet and wing tops and that's all it's getting. It's there as I use it for access to the roofrack(allright thats chequer plated as well, stops bits connecting with the roof
i'll have the entreq strengtheners? |
Doh!
The chequer plates have arrived and look very stable and smart BUT they have cut-outs for the mudflap mountings ![]() Looks like I will be using the Entreq strengtheners with them ![]() Sorry T1G UP ![]() But shout it at them in German because life is also terrifying and confusing... |
Just out of interest, which ones did you buy? I quite fancy some of the ones that are parallel to the bottom edge of the wing but whilst I've seen them on peoples trucks, I haven't found pictures of any for sale
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The ones I got are here: http://www.ebay.de/itm/370281047024?ssPage...1439.l2649 They go right under the wing, full-width, and have a cut-out for the mudflap bracket (exactly what I didn't want!). They also don't have a cutout for the wing support bracket bolt (a bit further forward) but drilling a hole in the chequer isn't so hard ![]() They come pre-drilled for the rivets, with rivets and with pre-attached sealing foam. You can choose the 2- or 5-stripe pattern. Very smart and pretty tough. I would ask the supplier about the above if there is a "next time". I'm going to fit them with the Nak. mudflap supports and a bit of extra butyl underneath (have fitted the supports just now as the wing was tearing already - Defender is only 6 months old!!!) The company Off Road Service seems pretty good - I have bought quite a few items from them before and been very pleased (their diff-protector is very nice). Not really useful for the UK though... Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
