Home > Puma (Tdci) > ALM settings question
djvanas
Netherlands 2013 Defender 110 Puma 2.2 SW Keswick Green
Hi All,
I hope this post finds you all well. I have a question regarding the ALM module in my Puma L316. I've had my fair share of isues with this unit and have a modification put in place to mitigate the poor design of the unit (dead battery = dead Defender).
Anyway - I recently bought a Nanocom to fix an issue that was bothering me for quite some time; no visual confirmation of lock/unlock. I have fixed this with my Nanocom.
However, I just wanted to check with experts here on the forum if my ALM setting make sense. The manuals that come with the Nanocom are pretty extensive although they only explain what settings are available but not exactly what the settings are for.
Would greatly appreciate your expert opinion!
Settings 1
Settings 2
Post #1018061 11th Dec 2023 3:19pm
MK
I am in the very same boat, but with the AS10 on my 2.4. Puma 110" SW
Post #1018075 11th Dec 2023 5:50pm
Ianh
When you say you have read the Nanocom documents have you read these ?
10AS https://www.nanocom-diagnostics.com/upload...0Guide.pdf
ALM https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu
Post #1018079 11th Dec 2023 6:11pm
djvanas
Yes - the document states what you can set, but not what the settings actually do.
Knowing the defaults would be convenient too 😁
Post #1018100 11th Dec 2023 9:14pm
