Home > In Car Electronics > Reverse Camera Rear View Mirror. Anyone have one?
mcma1
Does anyone have a Camera Mirror Kit fitted? I don't want a DD but would like to install a reverse camera and thought this might be a neat option.
Thanks Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1017003 1st Dec 2023 1:55pm
geobloke
Ponder on this from time to time.
As with you I do not want a DD head unit or an auxiliary screen on the dash. The best solution I have found thus far is the Optimill rear camera and number plate light twinned with the JVC KD-X560BT
https://www.us.jvc.com/car/marinemotorsports/kd_x560bt/
and
https://www.optimill-uk.com/number-plate-light-with-camera.html
A neat solution in my mind.
The other way is to go Pioneer SPH-20DAB with the reverse sensor pack
https://www.dynamicsounds.co.uk/pioneer-sp...ensor.html
A few options for you.
Post #1017010 1st Dec 2023 2:23pm
mcma1
Thanks for the details. I have the classic info head unit, all be it pretty useless I like the look so I need to find a mirror system. I see Halfords do a universal camera mirror kit which I may try. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1017065 1st Dec 2023 7:43pm
Naks
I have one of those universal units, fitted by my auto elec.
Works well, but be aware that it may require some trimming of the driver's/passenger's/both sun visors to fit properly --
Post #1017101 2nd Dec 2023 6:34am
geobloke
No problem. I like those classic look head units. The only thing to be aware of with the rearview mirror systems is that the mirrors are longer than the standard Defender one and it will foul on the sun visors. If that is an issue for you. Thumbs Up
Post #1017120 2nd Dec 2023 10:23am
bodstruck
I bought one off Amazon some while ago, was not that expensive. Picture quality was really good and as I had the headlining out anyway it was a simple install. As has been said, the mirror is wider than standard but I did not trim the sun visors, I just move the mirror if I need to put them down.
I think it is a cost effective solution that is not tricky to fit.
Post #1017392 4th Dec 2023 2:17pm
tooth_dr
Northern Ireland
Andy
I have the clear view mirror in my defender and I find it uncomfortable to use. When you look in a normal mirror your eyes have the same focal point as for looking out the front window. But if you have a camera mirror you have to adjust your focus onto the mirror face itself and I personally hate it.
Post #1017411 4th Dec 2023 4:44pm
