![]() | Home > Maintenance & Modifications > Eberspacher issues |
Hi John. I am sure you have had a google but this is an eberspacher error decoder
https://www.butlertechnik.com/eberspacher-fault-codes-i95 EDIT to include manuals for the D2 https://www.butlertechnik.com/technical_library/d2-airtronic-d8 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Cheers Guy I have been looking at them - which is how I found out how to read the error codes. 1999 Defender TD5 110
Figured you would have
![]() Also found this which lends weight to checking out the fuelling situation
It is a small bore pipe, might be partially blocked. |
A bit more reading https://www.letonkinoisvarnish.co.uk/eberspacher_faults_2.html
That's another thing to check at weekend, remove pipe from heater end, pump end and tank (separate one under the bonnet)
Also I think there is a gauze in the dosing pump 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yes it does seem to be a fuelling issue. Fingers crossed it is just a clogged up filter. Unless you are using kerosene or something in the standalone tank and it has waxed up over night.
Where is your D2 fitted? Always curious to see peoples fitting of these heaters. |
I am hoping its fueling as that's a fairly easy one to look at
I use normal diesel. Heater is located under the passenger seat and blows out under the middle seat 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Update
Cleaned out the fuel lines and the gauze filter at the pump end, which did have some grud in it. Checked the combustion air intake When I connected the fuel lines back up and set the heater to start I could see the fuel being pumped through the pipe to the heater Now get error 52/54 ![]() Back to the head scratching. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
This morning the heater fired up first time and got the car nice and warm before my early trip up the M6. I think this was a combo of two things.
1. Crud in the fuel pump gauze which didn't help 2. Possible low voltage at the 2nd battery. Time will tell. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Good to know and I bet the warmth is a luxury at the moment on the M6
Fingers crossed the issue is fixed. I might try it tomorrow morning to see.
The M6 was just damp this morning at least as far as Morcambe. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
