Home > General & Technical (L663) > Cleaning wheel arch trims, or extended trims?
Co1
My 90 see plenty of mud and dirt, and it cleans up very well however I can see and hear small stones and grit behind the wheel arch trims. I really don’t want to have to pop them off every time I clean it, so do the extended arches go any way to preventing build up behind?
Col
Post #1016423 26th Nov 2023 1:53pm
Clemmo
I get exactly the same!
I get a thin bladed plastic trim removal tool and wrap it in a thin wet fibre cloth.
I poke it in one end just a little and drag it around the arch.
The clips don't come off but the arch just gives enough.
Bigger debris drops through and dirt sticks to cloth
Clemmo Thumbs Up
Post #1016424 26th Nov 2023 1:58pm
lightning
A bit of poor design there
On our 2020 Jimny there's a flexible seal between the plastic wheel arch and the bodywork. This ensures no stones or grit can get behind.
Better still , the plastic wheel arches can be removed without breaking all the clips, and they fit perfectly unlike the ones on my new Defender where they've distorted a bit and the gap is different at some points.
Suzuki managed that on a vehicle that retailed under £20,000
Post #1016574 27th Nov 2023 9:24pm
Clemmo
Yup…mine are distorted too.
The dealer has said they will replace the rears for me when it goes in for service
(under warranty)
Clemmo
Post #1016580 27th Nov 2023 10:18pm
Co1
Mine are distorted as well. I assumed it was because there was mud etc behind! The extended arches have an adhesive section that run round the perimeter, does that do a better job of keeping the crap out?
Post #1016594 28th Nov 2023 6:46am
Moo
Ukraine
Would the extended wheel arches address the issue? They lift higher and are stuck to the bodywork. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1016605 28th Nov 2023 10:11am
Clemmo
There is no mud behind mine..they have just decided to malform.
The dealer didn't even look..which suggests they know its an issue sometimes
Clemmo Thumbs Up
Post #1016727 29th Nov 2023 5:38pm
