Home > Puma (Tdci) > Injector replacement bolt re torque?
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Following an eventful injector change the Puma is running like a dream.
My only question is that when I fitted the injector clamps with new stretch bolts the torque setting plus 180 degrees seems really inadequate. Once everything has bedded in after fitting and heating up and cooling down a few times surely they will slacken slightly even if they are stretch bolts?
Has anyone re torqued them after a while running in?
Post #1015070 14th Nov 2023 2:15pm
andy63
ive not done mine , but I have looked at the instructions I have for the 2.2l engine.. it indicates the hold down bolt can be reused once, torqued to 6Nm and then a further 360deg, and fit a new sealing washer.. don't recall anything about re visiting after a period of time..
Post #1015081 14th Nov 2023 4:03pm
SilverPuma
360 degrees would be a bit tighter at least 👍🏻 2010 2.4 TDCI Puma Defender 90
Post #1015093 14th Nov 2023 6:05pm
landhank
Germany
There is always a discussion if there is a difference between the 2.4l engine and the 2.2l engine.
The instructions say 360 degrees for the 2.2l but some say that its wrong in the instruction.
Anyway. I replaced the injectors on my 2.2l and 360 degrees worked fine.
Post #1015119 14th Nov 2023 8:41pm
