Home > Puma (Tdci) > power loss!!
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
power loss!!
My Puma started losing power from low revs. 2 or 3 days ago, when flooring it would slowly start to pull -- lifted the bonnet today and found this Shocked [
There is black soot everywhere - anyone tried similar. Will try to fix the cables - anyone think anything else could have been damaged.
Regards
CRJ
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #97712 2nd Nov 2011 5:04pm
ZeDefender
For those of us who are clueless - WTF is that chewed up thing?
Sad Sad Sad Tell someone you love them today because life is short.
Post #97714 2nd Nov 2011 5:15pm
CRJ
Ahh - sorry - it is the plug on the back of the turbo. I do not know what could have caused the cable to end up like that 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #97715 2nd Nov 2011 5:16pm
CRJ
And to correct my question - could the cut cable cause pressure in the turbo to blow a gasket or something ? 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #97716 2nd Nov 2011 5:22pm
BigMike
Have you checked the turbo pipes?
Post #97718 2nd Nov 2011 5:25pm
CRJ
I will take the shield off and check everything tonight - the gasket between the manifold and turbo was changed a month ago with a one piece thick copper - something. I will report back when the car - hopefully - is running perfect again. 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #97731 2nd Nov 2011 6:32pm
ZeDefender
Okay - this is probably a stupid idea but could it be mice? Several members here have had serious problems with the little Censored at this time of year Shocked
Not sure how cutting the wires could cause the soot though Confused Tell someone you love them today because life is short.
Post #97745 2nd Nov 2011 7:23pm
CRJ
About to change the two orange wires - they seem to be Cut by the ring they are wrapped around - why is that ring there? Some sort of metal (magnetic). Regards Crj 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #97763 2nd Nov 2011 8:11pm
ZeDefender
Some sort of EM shielding (from the blue ones)? Perhaps someone can figure out what all those wires do.
At least I'm keeping this at the top of "New Posts" Wink Tell someone you love them today because life is short.
Post #97769 2nd Nov 2011 8:19pm
Def-00
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Fuji White
Other than the turbo check the manifold, I had a crack in the exhaust manifold that caused black soot to cover the engine and underside of the bonnet. 2012 Fuji White 110 Flattened
Post #97815 2nd Nov 2011 11:04pm
CRJ
I have changed a length of the two orange wires - they were in pretty bad shape - and the car runs near perfect again. Could not find the location of the exhaust leak - but cleaned the engine and will look again tomorrow.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #97827 3rd Nov 2011 12:08am
Lorryman100
That is the Turbo modulator harness and the ring is the ferrite fuse. There is a service bulletin on the Modulator harness. Who fitted the annealed copper gasket?
Brian.
Post #97834 3rd Nov 2011 1:08am
CRJ
Hi Brian. That explains a lot - was wondering why the wiring had been cut/altered. The car is running again - I fitted the ferrite ring again - but I did not do any of the ign. on off as described in the bulletin - just started the car and drove off - hopefully it doesn´t cause any harm . The Copper gasket was fitted by my local Indy.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #97844 3rd Nov 2011 7:13am
ZeDefender
Lorryman100 wrote:
"That is the Turbo modulator harness and the ring is the ferrite fuse"
Great reply! To satisfy my eternal curiosity, please can you tell me what a ferrite fuse does?
Matt Tell someone you love them today because life is short.
Post #97848 3rd Nov 2011 8:17am
Lorryman100
Matt
Basically, the Ferrite fuse interacts directly with unwanted high-frequency RF energy and dissipates it effectively while allowing data signals to pass unimpeded along the harness to the EMS.
Brian.
Post #97986 3rd Nov 2011 10:38pm
