![]() | Home > Td5 > Oil on turbo to intercooler pipe |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1443 ![]() ![]() ![]() |
Probably be from the crank case breather.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5976 ![]() ![]() ![]() |
Cheers. I guess it could be from the PCV valve. I will break out the cleaning spray and a cloth and see what I can find. 1999 Defender TD5 110
I think they’re service items….
When my pcv was blocked, I also had oil on top of the rocker box |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Loose oil filter makes a mess and happens too.
Pretty sure thats OK, but I will check 1999 Defender TD5 110
Oil filter is nice and snug with no excess oil on the filter. 1999 Defender TD5 110
Was the oil a slick or just a residue on the silicone hose? Eventually the silicone hose can become porous and ooze oil under pressure. This happened to Miffys previous set of silicone hoses. c. 10 years old. |
Hi Guy, More of a light misting really and they are a few years old. I wonder if it is as simple? 1999 Defender TD5 110
It could be. I had a chat with Garry at Alive about it and he told me that when it happens you get a light covering of oil, sometimes a defined droplet or two. It does not drastically affect performance, just makes things greasy. I swapped out the hoses, problem cured.
My PCV caused a misting, and a small pool on top of the rocker were the breather connects. My hoses were only 12 months old so made it easy. Plus a pcv is only a few ££
