![]() | Home > General & Technical (L663) > Creaking drivers seat |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3444 ![]() ![]() |
Well this is clearly an issue that nobody else has experienced.
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 552 ![]() |
I mean..I don't like to say it but...perhaps there's another solution...!?
l don't think l would need that as l weigh only 70kg
I'll try to dismantle it and see if l can determine what it is. lf l put my hand on the seat under my bum l can feel something bouncing up and down when l drive over anything other than a perfectly smooth surface and you can't stop it by pressing down on it. Very strange. |
Sounds annoying.. maybe seat heating gubbins?
You were correct
lt was the wiring for the heated seat, l secured it with a cable tie and the fault is fixed. |
Nice!
Could you access it without tearing the seat down? |
