Home > Puma (Tdci) > Rear Brake
Naycrx
Rear Brake
Hi,
We seem to Have a binding rear Brake , any tips and maybe having a look myself.....Ie pumping out the piston cleaning it up...
Post #1012286 23rd Oct 2023 5:04pm
It's almost always more cost-effective just to fit a pair of new rear calipers.
Post #1012292 23rd Oct 2023 5:38pm
landy andy
My advice is to change both rear callipers for new items. They aren’t that costly, and it’s a proper fix. They don’t last long on defenders.
Post #1012294 23rd Oct 2023 5:40pm
Naycrx
OK, problem I'm having is , 4 week waiting list at our local garages to have a look.....
Anybody know of good mobile mechanics in Nottinghamshire /newark area
I'll look into buying a caliper windback tool and have a quick look
Post #1012296 23rd Oct 2023 5:44pm
landy andy
Any independent will be able to sort or it’s an easy DIY job if you have any ability.
Post #1012297 23rd Oct 2023 5:49pm
Naycrx
OK thanks....... the caliper wind back tool , Machine mart do one with the two spade like parts and then a socket winder on the top ....is this correct?
Post #1012302 23rd Oct 2023 6:09pm
htb2
Wales
no need for a piston wind back tool if you are careful, some form of lever will do.
Post #1012309 23rd Oct 2023 6:28pm
Naycrx
OK Thanks ......
My plan is to pump them out slightly give them a good clean up.... and the leaver them back
Post #1012311 23rd Oct 2023 6:32pm
As long as you are careful that might get you through the winter. If however you have one that has properly seized you probably won't shift it. Be careful also that you don't damage the ridiculously fragile dust seal.
Post #1012319 23rd Oct 2023 7:32pm
Ianh
If you’re after a tool that you can use to gently push back the rear and front ( it’s 88mm wide ) calliper pistons the neilsen ct0078 at circa £20 works well, it’s the same as the Clarke 5113 which is circa £62 at machinemart.
Post #1012352 23rd Oct 2023 9:10pm
MK
I just changed the rear pistons of a 110" and it was very easy. I did not change the seals as they were still good. Puma 110" SW
Post #1012371 23rd Oct 2023 11:41pm
Naycrx
After ringing our local garages and a 2 _3 week waiting time, I decided to attempt it myself.... once the pads were out the two outer seals were no good one perished and one hanging off..... spent a good hour or so cleaning ....pressing the pistons in and out ......
PADDOCKS, had a seal rebuild kit...... been for a run ....all ok 👍
I purchased a 11.99 windback tool of amazon .... this I could highly recommend and the build quality 👌
Post #1012611 25th Oct 2023 6:24pm
Screbble
Glad you sorted it 👍
Post #1012615 25th Oct 2023 6:37pm
