Home > Puma (Tdci) > Sunroof glass removal - is it possible?
Kez
Isle Of Man
Does anyone know how to remove the sunroof glass (its an 07 XS) would like to see if I can improve seal, but cant see any obvious way of lifting it out Neutral
Post #97335 31st Oct 2011 5:27pm
JSG
Wind the 'wheel' to open the sunroof as much as possible, then pinch the catch to release it and lift the glass out.
Should be shown in the owners manual. John
2011 Tdci 110 CSW XS
Post #97343 31st Oct 2011 6:08pm
Kez
Isle Of Man
Must admit thats what I assumed from previous vehicles but nothing seems to want to budge, is it simply stuck or is this version different in some way (see pic below) obviously I don't want to brake it as no sunroof glass is worse than a slightly leaky one Big Cry
Post #97501 1st Nov 2011 2:37pm
JSG
You just need to push the two blocks (one shown behind the wheel) in towards each other and it will lift out. Thumbs Up John
Post #97503 1st Nov 2011 2:42pm
Kez
Isle Of Man
As I said above, there is no movement at all from the blocks mentioned, so I did what any sensible person would have done in the first place and...... resorted to reading the handbook.
So in case anyone else has the same sunroof, what you do is wind up sunroof as far as it goes, then facing down into the car you will see a small sliver catch exposed (shown on left of image below, looks like a birds beak), press this up to release the opening bracket and lift out sunroof - simples Very Happy
Post #97514 1st Nov 2011 3:51pm
Kez
Isle Of Man
Well, guess what... removed rubber seal as sunroof would occasionally dribble in water, had tried the Vaseline trick but that did not seem to improve things so took out seal, put some padding in the form of some 5mm cable in then put rubber seal back in. Had read this sometimes works, well my slight occasional drop has increased to the kind of flow a shower manufacturer would be pleased with. Passenger seat is socked as indeed is my head....arhhhhhhhhhhhhhhhhhhh Big Cry
Post #97872 3rd Nov 2011 12:08pm
Happyoldgit
Pssssssssst - take out the cable Wink
Get shot of the Vaseline and try a smear of silicone grease. IIRC the sunroof is pretty much the same as the one or two I had in my TD5 & 300Tdi's. They don't have go with a bang if they get hit by a stone while you are doing 70 Wink Steve.
http://forums.lr4x4.com
Post #97903 3rd Nov 2011 3:35pm
Kez
Isle Of Man
Cable removed, gutter cleaned, rubber seal cleaned and replaced then lubricated with some silicon grease - no improvement, as bad if not worse than when I started Big Cry
Post #98430 6th Nov 2011 4:36pm
mse
Clear the drain, remove all the gunk you have put on, place the seal firmly down, check all the glass to frame mounts are tight and seated in the lowest position and refit. Mike
Post #98438 6th Nov 2011 5:18pm
Kez
Isle Of Man
Way ahead of you Mike, just did exactly that, leaving it all to settle down overnight before testing (there's only so many a failures man can take in one weekend) - is it wine-oclock yet?
Post #98440 6th Nov 2011 5:21pm
leeds
YES
Next question please
Brendan
Post #98447 6th Nov 2011 6:34pm
Kez
Isle Of Man
Just q quick follow up out of courtesy, as suggested above I removed the seal, cleaned everything (even washed glass in sink to ensure it was literally squeaky clean) put it all back and..... it worked. Three rainy days later and its still watertight.
Needless to say no sooner was that fixed then something else want wrong, but I post that separately ...sigh Rolling Eyes
Post #98894 9th Nov 2011 9:57am
mse
Great
I hope it stays dry Mike
Post #98955 9th Nov 2011 5:01pm
GregK Myanmar
2010 Defender 110 Puma 2.4 SW Stornoway Grey
My sunroof got hit by a rock and shattered into small pieces. Luckily I had window tint on the inside of it so it stayed in place held by that film long enough for me to tape it up.
I have had the car 6 years and never realised you can remove the sunroof. Some of the links above to images are broken so here is a link to show the clip that holds in the glass.
https://www.dropbox.com/s/ulx1nmud7xris1o/...e.jpg?dl=0
The replacement part no. is AWR3323 which is now LR045874.
Post #553656 4th Aug 2016 12:15pm
