- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Westy
| Strands siberia sr led light bar with position light wiring | |
Good day all,
This weekends plan is to fit a Strands Siberia SR light bar that has a position light.
I have the contura switch sussed, i think, but I'm thinking the position light wire (white) from the light bar needs to connect to the sidelight wiring somehow?
I have also have a Stedi light bar on the front which was linked to the head light high beam with an isolation switch to turn it off.
However when I switched the cheap stedi switch to the Contura switch fitted in a Mud housing the ability to turn the light on with high beam has stopped working so any advice here also appreciated.
Thanks in advance G
Apologies if this appears in the wrong feed
16th Sep 2023 10:58am |
