Home > Technical > Right indicator works,left don't
Holmkiern
Sweden
Hi all, trying to fix all electric for MOT and next topic is indicator dont work on left side. On right side it work and a nice clicking sound from relay. Silent when try to indicate left.
One thing I dont understand: there are 4 connecting pins on relay. One earth,one current,one in and one out. How can relay separate which side it should indicate? Should it not be 2 in and 2 out?
Pins were heavily corroded on relay but cleaned up.
All best johnny
Post #1006987 9th Sep 2023 11:49am
landy andy
Indicator issues are often the hazard switch as they combine the systems.
Post #1006989 9th Sep 2023 11:52am
Martin
Site Admin
The column stalk connects the output of the flasher relay to the correct lights.
As it works on the right, this suggests the flasher unit is ok as well the supply to it, and the feed to the stalk.
It points to the stalk itself being at fault. To check this, remove the column shroud, and find the connector for the stalk. Disconnect the stalk, and check the plug and socket for pushed out terminals.
Turn on the ignition, and on the harness side connector (plug), get a short piece of wire and connect the light green with brown stripe wire (pin 3) to the green with red stripe wire (pin 4).
You should get left hand indicators. If so, then the stalk is faulty, perhaps a loose or bent contact in the switch.
If not, this suggests the wiring from the stalk to the header which splits out to all the indicators is broken.
Try the test above and let us know Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1007006 9th Sep 2023 3:15pm
Holmkiern
Sweden
Well,after some checks I found 2 lamps was loose in holders + one connection to earth was disconnected for front left.
The position,indicator and brake light holders are rubbish since the lamps pops out after a while.
Mayby LED could be an option.
Post #1008517 22nd Sep 2023 7:24pm
