![]() | Home > Maintenance & Modifications > Rear forward seat - modified for more reclining |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 203 ![]() ![]() ![]() |
Yes, I have done this to the 3rd row seats in my 110 Puma some years back.
Do not expect to gain a lot, however I have had no adverse effect, so no reason not to do it. Unfortunately I have no pictures to share, but once the necessary trim and plastics are removed to reveal the mechanism it shall be relatively obvious as to what must be done. For each seat, it requires removing one round bush on one side and one steel washer on the other side. The steel washer is point welded to the seat frame, an angle grinder is your friend to take it out easily. /Mat |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
When I picked up my rear seats from a forum member, they also came with a kit to allow more reclining of the rear seats. I can take pics if you want Dinnu ? 1999 Defender TD5 110
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
Thank you for the replies. I admit I have not done any investigation, but will do … the question popped into my mind as currently traveling with the car as SWMO makes all excuses not to use the Defender
![]() Excossak, are the Td5 seats with same mechanism? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Not sure Dinnu. I will take some pics tomorrow and Whatsapp them over to you if OK ? 1999 Defender TD5 110
Thank you for the pictures John. Top man
![]() Will see what I can sort. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
No probs.
I wonder if front seat reclining mechanism can be adapted to fit? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
That could also be something as the front seat backs are able to go flat on the base if they do not hit the dash. But I hope I find something that only needs minor modification to the current seat frame. Need to find time to investigate Mat’s suggestion too 👍 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
