Home > General & Technical (L663) > Confused? heated seats X-Dynamic S (P400E) 2024 |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1331 |
If you have heated seats the switch is the temp control, you push this in and turn, You can also access the settings through Pivi, if I remember rightly.
This is the button to press Click image to enlarge and you would twist it to switch it on, there are 3 levels, here on mine it is actually the cooling seats which are switched on Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
27th Aug 2023 5:48pm |
Just had a look in the Iguide and it is covered under climate and comfort
Click image to enlarge Click image to enlarge At least it is in the My2022 version Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
27th Aug 2023 5:53pm |
macduff Member Since: 04 Nov 2012 Location: NE Posts: 117 |
Ta all i was searching iguide for Seat , heated Seat or Heated the latter only finds heated wheel. Searching for seat te finds it 2023 110 P400e
27th Aug 2023 6:01pm |
Just to update I didn’t appear to have the seat icon on the climate knobs & pushing them didn’t show anything regarding seat heating. Found I needed to use the seat App on Pivi where both seats were shown as off, I couldn’t turn these on whilst it was plugged in /charging but turned on ok with it running, I left these on but with no heating & this then put the seat icon on the climate knobs. 2023 110 P400e
29th Aug 2023 7:55am |
I'm glad you've got it sorted Cheers Ian
29th Aug 2023 8:11am |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 122 |
You can also use voice control to turn the heating on. Something like "Hey Land Rover, turn heated seats on". Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
29th Aug 2023 9:14pm |
