![]() | Home > Td5 > TD5 Air Con |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 ![]() ![]() |
Yes. They have a trinary switch.
A high, medium and low switch. The high and low control the compressor and the Ned controls the cond fan. Steve. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1282 ![]() ![]() ![]() |
The refrigerant r134a carries the oil around the system, no gas means the compressor would loose lubrication so the low pressure switch is there to save the system from self destruction
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 981 ![]() ![]() ![]() |
Thanks guys
Jim |
As above. Spot on answers
