Home > Off Topic > What is this? Heavy Metal.
Spruce Pirate
Scotland 2013 Defender 110 Puma 2.2 HT Zambezi Silver
I'm clearing out our old sheds and getting rid of stuff and have come across this:
It came from a Scottish Water shed years ago when they were clearing out and was in with a load of other Land-Rover stuff which I got from them. I'm not sure exactly what it is or if it is a Land-Rover part or not? Does anyone recognise what it is? What it's for? It's clearly got a towing pin and doesn't look as though its been used. Lastly, is it of any use to anyone, does anyone want it before it goes in the scrap pile?
Thanks Dirty Deeds - Done Dirt Cheap
Post #1005095 22nd Aug 2023 10:08am
I'd say it is a towing point (probably front but possibly rear) from an LGV or HGV, it is not a Landrover part and there is no readily obvious way of using at such.
The side plates would bolt to the chassis rails.
Post #1005102 22nd Aug 2023 10:48am
Spruce Pirate
That seems like a very reasonable diagnosis. I wasn't sure if it was a tractor part, hadn't considered HGV but Scottish Water did used to have a couple of sheep floats so could be. Dirty Deeds - Done Dirt Cheap
Post #1005108 22nd Aug 2023 11:03am
Good point, it could also be off the front of a tractor.
Does it have any makers markings or part numbers stamped on it? I am sure it would cost a bundle if you wanted to buy one!
Post #1005109 22nd Aug 2023 11:05am
Blackwolf wrote:
... it could also be off the front of a tractor. ...
Like this (which would explain the shape of the top, to hold front weights). Mystery solved, I think, but what kind of tractor?
Post #1005110 22nd Aug 2023 11:10am
