Home > Puma (Tdci) > CB Radio |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
mines screwed onto the side of the cubby box ,tucked down as far as poss.
Had no problems .. and easy to wire in Guns and Landrovers .... anything else is irrelevant. |
27th Oct 2011 9:17pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Mines on the back of the cubby box. Works well as long as you dont need to change channel too often or look at it for any reason.
27th Oct 2011 9:33pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
mines on the front of my cubby, the mike clip screwd to one of the blank switches so as not to put holes in my dash, but my cubby is a non standard size and not sure it would work with a standard cubby.
27th Oct 2011 9:37pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
On the Roof Console :
http://davidecorsetti.files.wordpress.com/...-radio.jpg http://www.roverworld.com/roof_console_english.htm Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
28th Oct 2011 9:00am |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 |
I mounted my remote head Uniden UHF unit on a ply insert I bolted to the underside of the cubby box. That way I have not had to drill into the dash or other areas. The main box is under the driver seat with a remote speaker fitted to the right of the head. The speaker could easily be hidden behind the dash if required.
Will have to change it in the next few years as we are going to 80 channel UHF. Click image to enlarge |
28th Oct 2011 9:45am |
Side of the cubby box secured with double sided body tape direct to the body of the rig. Power straight from the battery and feed cables via grommet in the seatbox. Steve.
28th Oct 2011 10:32am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
On this one I bought a secure cubby box and mounted it in that so it could belocked away.
On the defender before that one I mounted it on the rear of the factory fitted cuby box. Boy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
28th Oct 2011 12:02pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
same as The Boy, MSS cubby box
Bob |
28th Oct 2011 12:07pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 652 |
Is that some kind of time machine mounted to the front of it?
I'd try the same, but Td5s won't do 88mph |
28th Oct 2011 12:10pm |
Na its a marine switch pannel that controld the extra lights/fridge/worklights ect.
If it had been a time machine I would have gone back and NOT bought that perticular land rover Boy |
28th Oct 2011 12:20pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
I used the MSS route in the Tombraider 90 - but they won't fit the Pumas unless you lose the cup holders which I NEED for my coffee John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
28th Oct 2011 12:26pm |
John
I drilled new holes in the cubby box floor and moved it back a couple of inches. Does not protrude into the rear foot area too much and I can now use the cup holders Bob |
28th Oct 2011 12:37pm |
Hmm, bit late now as I fitted a Nak under cubby safe.
Good idea though - should have thought of trying that before John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
28th Oct 2011 12:46pm |
