![]() | Home > Maintenance & Modifications > Rear door struts |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
Since changing the back door to after market one, the door didnt come with the catch on the bottom sliding door stay as you can guess, on a slope the door closes over
![]() What are the options for door struts ? for example, looking on https://www.4x4overlander.com/product/defe...-pre-2002/ Not sure if this fits top or bottom of the door What are thoughts on door struts? good, bag, ugly ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
"allows the door to open slowly and stop gently"
that is nice. But no pics of it fitted. I will drop them an email to find out more. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3635 ![]() ![]() ![]() |
Judging by the brackets, looks like it fits at the bottom. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
https://bisonautodesign.co.uk/products/rea...-stainless
Check this one out as well. Saves a few bucks. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I have the Naka rear door V2 strut if you want photos. It does open the door with the Safari Equip wheel carrier and 285/75/16 wheel on and it does hold the door open on a slope. The latter bit is what I wanted the most.
Only down side is the closing is heavier than normal. EDIT: Actually I have to take the door trim off anyway to get the wheel carrier off in order to refurb it, so can get good pics if wanted. |
Cheers a pic or two would be handy please - just see see how the mount sits and I can compare to the aftermarket door 1999 Defender TD5 110
Good luck. No storms here (as of yet) but some clouds are appearing. 1999 Defender TD5 110
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 611 ![]() ![]() ![]() |
I fitted the Naka gas strut https://www.mudstuff.co.uk/collections/nak...-gas-strut
Very happy with it. It has a soft open so the door does not come to a sudden stop when fully open. The strut is strong enough to hold the door open on a steep slope. Really easy to fit. |
Not a chance tonight ![]() ![]() |
No worries GB. No real rain for us, just a few spots 1999 Defender TD5 110
I am fairly certain I saw the Ark floating past in the gloom yesterday evening
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1875 ![]() ![]() ![]() |
I fitted one of these and it was simple enough to install. One bracket replaces the current bracket mounted inside the tub, the other end fits behind the door card, and from memory needed two holes drilling in the door frame. Sorry no pics though.
Works a treat, although I would say be careful with anyone who is either small, or doesnt know its fitted, as once its unlatched its opening. Its flicked more than one child off the rear step! Once installed the door card fits over the top and you barely notice its there. They also do a V3 version which mounts at the top of the door but isnt as discrete. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1130 ![]() ![]() ![]() |
A different approach if you, like me, don't like the force needed to close the door:
https://www.wmparts.de/produkte/anbauteile/hecktuerhalter/ Basically like 'storm hooks' for old-fashioned windows ![]() |
