![]() | Home > Maintenance & Modifications > Help needed with a strange water leak |
Thanks for the pictures Martyn, very helpful
![]() First major leaking area found and fix in progress. Fold the rear seats forward and remove any covering you have under them. You will see a panel that runs from the front of the seat boxes to the back and it is butted against the wheel arches. The joint is just the top panel sitting in an overlap panel underneath. When I pressed down on the joint water came out. On closer inspection the two sides and front are not flat and there were 1/8" plus gaps on the sides and at the front there was at least a 1/4" gap in places ![]() I am going to leave the sealer to dry overnight. I have cleaned the underneath of the arches and will leave that to dry. Then I am going to apply waxoyl. Also removed all the trim under the rear windows but no sign of any leaks there. One down - not sure how many more to go ![]() Bob |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
Good work Bob, when you've finished yours you can do mine if you want
![]() 110 HCPU Tipper |
Get the beer ready
![]() On second thoughts, better wait until I have a dry rear ![]() Bob |
Update.
Having spent a good hour jet washing the wheel arches and underside of my Double Cab today to get rid of Salisbury Plain, there was no water under the rear seats or on the rear floor - fixed ![]() Not undersealed the arches yet so it looks like sealing the plate under the seats has done the job. Same can't be said for the water that is getting past the passenger side front door seal though and running down the inside of the seal. Job for another day. Bob |
