Home > Maintenance & Modifications > Saggy rear headlining
DAZ110
My 90 was suffering from a case of saggy headlining in the rear so I put a self-tapper screw through the hole inside the interior light into the roof strengthener and added 3 additional fir tree clips:
Saggyness now gone. Thumbs Up
Post #1001827 26th Jul 2023 12:31pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
I'm just being lazy, what size hole did you drill for the Fir trees,
Looks factory Thumbs Up
Post #1001828 26th Jul 2023 1:03pm
L110CDL
Looking good there Daz, and i thought the same, looks factory fitted Thumbs Up Clayton.
Keeper.
Post #1001913 26th Jul 2023 9:02pm
DAZ110
Thumbs Up
Tried 5mm then 6mm to start but was too small for the fir tree clips to go in, so ended up being 6.5mm…..and a good whack with the hammer.
Think I saw someone on here went to 7mm.
Post #1001926 26th Jul 2023 10:22pm
rustandoil
On my 110 DC the factory holes were mostly 6mm.... There was now way the new fir tree's would fit... After experiment ended up with 7.2mm holes. But I suppose it depends on the fir tree's themselves, got mine from YRM
Post #1001942 27th Jul 2023 6:10am
Screbble
Re: Saggy rear headlining
Looks good 👍 job well done.
Wish I could solve my saggyness!
Post #1001953 27th Jul 2023 8:36am
DAZ110
My fir tree clips came from here:
https://www.ebay.co.uk/itm/Land-Rover-Defe...ect=mobile
The self-tapper through the hole in the interior light certainly helped, but it did seem that it needed the extra fir trees to support the weight of the headlining.
Also the rear 90 headlining has an unused fixing hole in the centre rib - it seems to be punched through the board but the fabric is not punched through - you can feel for it then use that as a starting point. It’s where the fir tree in my photo that has a flat spot on it behind the interior light.
Post #1001954 27th Jul 2023 8:39am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I've done something similar some time ago, but instead of adding a self-tapping screw, I used a rivnut.
I did not add any additional fixings though, it seems to hold reasonably well so far.
 “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1001973 27th Jul 2023 11:10am
shanecl
Thanks for the replies lads. Will give it a go
Shane
Post #1001975 27th Jul 2023 11:51am
