![]() | Home > Td5 > Clicking noise on full lock? |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Yup classic CV joint noise
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
likely CV joint. Before dismantling it might be worth checking the endfloat/shimming of the splines into the driveflange. If there is a lot of endfloat here it can cause the CV joint to locate too far inwards and bind up on lock.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
I did think CV..
![]() End-float. I didn't know the drive flange had shims. Are the shims behind the flange? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Sorry my description wasn't great! The shim is between the circlip and driveflange on the outside (under the rubber cap if you have original style flanges). 02' 110 TD5 Double Cab Rebuild Thread
Oooh.. cheers. Not sure if I have noticed a shim there.
Still have original drive flanges - certainly the standard type 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Here you go John
Number 12 https://www.lrworkshop.com/diagrams/land-r...6_52605#12 I have this on my list to check since I now have a DTI sitting downstairs ready to do the rear diff centre. This is the instructions: ![]() Click image to enlarge End play should be between 0.08-0.25mm ![]() EDIT: coming to think about it if you do not have a DTI then when we meet up we can check yours in the car park ![]() |
Cheers Guy. I do have one...but currently in a box in the F-i-L's garage as I am rebuilding the shed...
21 supermarket stackable crates currently house the contents of the shed! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yikes
Yup. Its only a 10x8.....new one 10x10.... 1999 Defender TD5 110
Oooo an extra 2x10 space. Sounds like a decent sized work bench to me
Hope so as well. 1999 Defender TD5 110
