Home > Puma (Tdci) > Rear door central locking not working. (Not split wire)
Jame5mac90
 2012 Defender 110 Puma 2.2 XS CSW Alveston Red
Just upgraded to a 2.2 puma 110 CSW and the central locking on both rear doors isn’t working. A quick google search pointed me in the direction of a broken wire in the flexi rubber. One of them was broken so I replace it and it still doesn’t work. I disconnect the plugs in the pillar and applied power manually and both door mechanism work so the problem is obviously further back.
While having a look under the driver seat I found 2 unplugged connections with the same coloured wiring as the central locking so I’m assuming this is the issue. Any idea where these 2 plugs go. They are both male so won’t connect together am I missing some sort of central locking module?
Any help would be appreciate, I’ll see if I can apply some power down these line tonight and see if they activate the door too.
Post #1000540 17th Jul 2023 3:38pm
Jame5mac90
Post #1000541 17th Jul 2023 3:39pm
Jame5mac90
Iv no idea how this happened but basically one of those plugs should have been female. 10mins and a couple of new terminal later and all the central locking was working.
Post #1000576 17th Jul 2023 6:18pm
Martin
Site Admin
Fantastic, well done!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1000587 17th Jul 2023 7:21pm
