![]() | Home > Maintenance & Modifications > Key fob case 2014 2 button type |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3648
Not sure if 2014 is same as the earlier, but I got one from here, and pleased with the quality (and the price
All I needed is to transfer the internals, which is as easy as replacing the battery. https://www.aliexpress.com/item/3302803724...1762247170 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176
Thanks for the reply! Although your replacement gave you change out of £2, I don’t think it’ll fit mine. Plus, I’d happily spend a bit more to get something close to original. But certainly not £100+ and the rest. Here’s what mine looks like.
Click image to enlarge |
| ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 188
I'm also interested if anyone has a solution as mine's the same as you describe.
Chris |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
Is this thread of any help ?
https://www.defender2.net/forum/topic84654.html Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
