Home > Maintenance & Modifications > Coolant Leak….
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
Coolant Leak….
Noticed under the car this morning a round wet patch, now whilst this is nothing unusual with leaks this one was quite large - I put a piece of cardboard to see the extent and when returned hour later saw that it was coolant and not oil as first suspected.
Cannot see any visible leaks it is coming down behind the n/s wheel. Topped the coolest back up as was low.
Any ideas, cracked hose somewhere behind engine etc?
Post #997120 22nd Jun 2023 1:26pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Further photographs are required, from above and below, to have a go at saying where the coolant originated.
It could be a core plug, a leaking hose, a split heater matrix, or the water pump. Essentially, it’s impossible to say from just a pool underneath as fluids don’t always hit the ground directly below the point from which they leak. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #997124 22nd Jun 2023 1:37pm
landy andy
You sure it’s not condensation from A/C?
Post #997126 22nd Jun 2023 1:41pm
MattyEssex
Andy no it’s def red fluid cannot see anything visible from pipes etc
Post #997128 22nd Jun 2023 1:48pm
geobloke
Which engine do you have? What does the fluid feel like, is it oily or watery or sticky?
Post #997137 22nd Jun 2023 2:37pm
MattyEssex
It’s the 2.4 Puma, it’s watery issue is I can’t get in to have a look, will try later from getting under it to take a look.
Post #997138 22nd Jun 2023 2:42pm
geobloke
So being that it is watery and you have a RHD I am going to say something to do with the heater box, AC, hoses or matrix. Get up above the heater box with a decent pen torch and see if you can find the tracks of water. If there is nothing apparent externally then it might be more matrix/core related.
Do you have AC?
Post #997139 22nd Jun 2023 2:52pm
MK
Fuel cooler or oil cooler. Both easy to spot from underneath. Puma 110" SW
Post #997141 22nd Jun 2023 3:00pm
hank
Check the heater valve. These can fail and leak > 110 XS Double Cab
Post #997159 22nd Jun 2023 5:04pm
MattyEssex
Do you have AC?
Ok will check all around tomorrow, yes it does has AC
Post #997176 22nd Jun 2023 7:28pm
