jst
Various Def tdi parts, some disco tid and some suspension. | |
Am looking to shift some of this lot.
Buyer arranges collection (Taunton)/Relay
Qty
1 TJM Rear Pin/Eye def HD + 2" shock £10
4 OME N44 front shocks (pin/pin) £10 each
1pr Ashcroft rear shafts NEW, suit early stlye axle casing £220
1pr Ashcroft front shafts NEW, suit early style axle casing £200
lots 300tdi air filters (def) £5ea
5 Black (but need repaint) Wolf Rims (Tubeless) Offers
1 200Tdi Genuine def engine with 96k miles, needs S/M, pipes, PAS pump rest complete. £350
1 200 Tdi Def intercooler/rad/fan cowling and framework £100
1 300Tdi back plate, flexplate, Starter ring and Torque Converter Offers
1 300Tdi as NEW condition Discovery Rad £75
4 +2" Defender Springs 150lb each. Offers
1 93 aged Def dash FOC
1 93 aged Defender heater box complete £20
1 Disco 1 tow drop tow hitch with chassis arm mounts. £15
1 90 underseat fuel tank with sender £20
2 M Reg 300 Tdi Disco front wheel stations (hubs, discs, CVs shafts) no Calipers FOC
2 300Tdi header tanks plastic £5
2 -2" rear drop shock mounts (eye) £10pr
2 -2" front shock turrets £20pr
2 Rear top dislocation relocation cones £15pr
1 td5 intercooler £10
1 M Reg 300Tdi Disco gbox X Member Offers
1 300tdi a/c pump - condition unknown Offers
pr 110 Stornaway grey std side sills - the lower side panel on the vehicle £10
pr 90 Red std side sill panels £10
3 24 Spline Std 2 pin diffs £75each
1 TD5 Def Servo + Pedal box £30
1 Def Clutch box complete with M/C and pedal - working when removed £15
1 Std Def PAS bottle (later style) £5
1 90 HD Sumo drag link £20
1 td5 throttle pedal assembly complete (def) £5
1 Def C Reg brake servo £20
1 Def L Reg 200tdi Servo with MC (STC441) £45
1 Disco 1 Servo and M/C £45
pr Cranked scorpion Radius arms with new bushes - suit L Reg onwards Offers
1 1.2 T box from 93 Reg disco £80
All of it is used apart from the Ashcrofts shafts which were kept as spares but are no longer needed. There is no Warranty with them.
The price reflects the fact it is used.
All parts working when removed with the exception of the a/c pump whose condition is unknown. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
23rd Oct 2011 9:51pm |
