![]() | Home > Puma (Tdci) > Help me identifying my disk |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
Hello all,
Got a bit of a random combination of disc's on my def, Front is AP racing 6 pot with AP disc, rear is a AP calliper / spacer with what i believe is a standard front 110 disc. I am currently oversea and want to order all the parts to do a few maintenance pieces before MOT Could anyone with more knowledge confirm that this is a standard front vented disc and nothing else? Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Would this be a good replacement i guess? I may try and source a AP set of discs for the rear. https://dbabrakes.co.uk/discbrakes/21591/DBA-4549S |
I know the groves are non standard, they were machined in to somewhat match the front AP discs.
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
If thats the Rakeway kit, then I'm sure the rear disc is a Defender (post 1994) vented front disc, with the hub machined to give the correct offset.
But technically should be 298mm and a total width of 70mm ish IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Can you supply something to replace it? Would even consider a genuine ap disc
