![]() | Home > Puma (Tdci) > 2011 PUMA Power Delay |
| scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571
What was it like before you removed the engine components and had it tuned?
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I would email Pete at BAS and tell him what mods you have done since first purchasing the remap. The throttle lag/latency can be fixed in the tune as Gary did that with my Alive tune. It sounds as though you have some flat spots which seem to be more noticeable now with the changes you have done to the exhaust system. All of it is fixable by redoing the remap file so drop BAS an email with everything you have changed and I'm sure he will get on to it.
Brian. |
| pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
mine does that as well, there is a lag from when you take your foot off the throttle until the revs drop.
The loaner I had during service did it as well. Pom |
| fontes Member Since: 29 May 2011 Location: Coimbra Posts: 35
The same but with less power. I just noticed how bad It is because it was the first time I took it offroad. |
I hope so but the problem with standard tune is even worse! |
| pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273
I've have the same symptoms on both my 2009 and 2011 Puma, I've learned to live with it. I don't think the anti stall helps at times whilst off roading as this can cause slight acceleration at the wrong time.
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
As stated in previous threads....
Remaps are produced for certain vehicle configurations, should you alter these configurations for example with larger intercooler, decat pipe, or big bore exhaust etc. unless the map (be it original or otherwise) is configured for your enhancements there is a danger it will throw the map out and your vehicle will not operate correctly and or run like a bag of spanners. It could of course also be something simple like a MAF sensor or EGR Valve As suggented in your case BAS would be my first port of call. Running rough on the standard tune I would look at what you have 'tweaked' since then or a component failure. Good luck! Treat every day as if it is your last....one day you will be right!! |
Hi, Iīm in touch with Pete at BellAuto, what Iīm trying to understand is if this is a "standard" flaw on td4īs or a particular case in mine, as far as I know the maps where made for the changes I have in my vehicle. Regards, Paulo Fontes |
In my experience it is most definately NOT a standard flaw on TD4s. Mine ran 'quite sweet' as standard and the only flatspot is when I hit the limiter! Again good luck in ironing out your flatspot! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655
Surely if a spot is flat, ironing it is the last thing you'd want to do? Anyway I don't think any electronically controlled turbo-diesel is ever going to have the instant response of a big petrol engine, even if they do have similar torque figures. Most of that torque is reliant on the turbo which always introduces some kind of a delay (unless you go for a silly sized one, which could give you instant response but no top end). Last edited by twopoint6khz on 23rd Oct 2011 8:23pm. Edited 1 time in total |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Not noticed it on either of my Pumas John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I donīt know if I explained myself very good, itīs not on normal use, itīs driving the car flat out off road. Itīs road manners are impeccable. What Iīm saying itīs for example reeving 2 gear as much as possible and changing to 3 as fast as possible, almost without decelerating. |
I got that - I've not noticed it with either of mine off road. I'm not sure I'd drive flat out off road though so maybe that's why. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Good point! Well presented!
Me neither, also unless you are on a flat plain with a good solid surface how can you tell with so many variables to consider and take into account such as terrain, surface traction, engine loading etc. etc. especially 'flat out'? You describe your gearchange as 'almost without decelerating' but decelerate you obviously are....by how much exactly? Must be difficult to gauge surely? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| All times are GMT |
