Home > Td5 > td5 sunroof (twist knob version)
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
I'm at the moment getting the cassis ready for a fresh coat of paint and would like to remove the sunroof to get the paint properly done. Somewhat I cant figure out how to remove the sunroof .. from the schematics there should be one screw that is holding everything down but i cant see it.. could someone share with me the location for it?
thanks a lot
 Td5 110 Station
Post #994180 27th May 2023 8:03am
geobloke
There are about 18-20 screws holding the frame in position.
To get to the screws take the glass out by raising it on the twisty knob. There is a little metal latch on the back of the knob, this allows the removal of the glass. It pivots towards the front. The front hinges are just curved sliders within plastic sockets. Then pull the upper seal out and below are the screws you need to get to.
If you need photos I can pop out and get them for you Thumbs Up
Post #994186 27th May 2023 9:05am
doruk1981
Thank you so much for the hint. Sunroof is off and paint finally sanded down for the repaint Td5 110 Station
Post #994480 30th May 2023 12:28pm
