![]() | Home > Puma (Tdci) > Traction Control / DSC Problem |
| drivetrainshunt Member Since: 27 May 2023 Location: Surrey Posts: 13
I'd be interested to see how you got on with this?
Mine will do a rattle (a bit like abs kicking off type thing) when maoevering on tight lock too. |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Mine did this for a few hundred miles from new, then settled down. It sounds like the traction control unit powering up ready to work.
Not worked on the system but a few pointers: Check wheel sensors for seating- they may need tapping in Check wheel sensor wiring an connectors for damage/ corrosion The steering angle sensor is difficult to set up, particularly with aftermarket steering wheels There is also a yaw sensor, but not certain how you would check this other than fault codes. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
Can you not disbable abs/etc with 10 pumps of brake pedal straight after igniton on? Or that maybe just the siemens system. I forget now.
Mine did this, 10 plate, at 60k miles, no dsc. In the end having got most partd ready it ended up being on of the connectors jist had bit of corrosion in it. Seems you have looked at dsc fault causes so far, could be simier than that and just an etc fault. Wheel sensor, connector. What does diagnostics say? Anything? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| All times are GMT |
