Home > Maintenance & Modifications > Transfer and Diff service TD5 |
Karlchadw Member Since: 18 Oct 2022 Location: Leicestershire Posts: 8 |
I know this has been asked so many times, so apologies. But getting myself confused with all the recommendations on previous posts.
www.opieoils.co.uk/p-739-castrol-transmax-...fluid.aspx Looking at this for the transfer box And this for the diffs - https://www.opieoils.co.uk/p-724-castrol-t...fluid.aspx Have got MTF94 for the gear box from Smith & Allan Have I got this right?[/url] |
24th May 2023 11:12am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4350 |
In a TD5
the diffs need EP90 https://www.smithandallan.com/product/smit...r-oil-4062 the R380 needs MTF94 https://www.smithandallan.com/product/smit...fluid-4070 This is what I use in Miffy anyway. I like S&A top company to deal with and quick to deliver. |
24th May 2023 12:03pm |
Just going to add that if you have a RoamerDrive overdrive in your LT230 then you cannot use the 75w90 listed above as it is a multi grade GL4 and GL5, so not suitable for the brass within the overdrive.
I do have an overdrive so I use MT(f)90 in the LT230 which is a 75w90 but only GL4 and safe for the Romerdrive. |
24th May 2023 12:29pm |
