![]() | Home > Td5 > td5 head bolt sequence - really 5 step? |
Yes you must do all the steps. The head bolts are stretch bolts and need the incremental torquing down.
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 32 ![]() ![]() |
It is assumed that you have blown out the holes where the cylinder head bolts screw in, because if there is any oil left in them, this oil can cause the cylinder head to not fit well
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
damn no i didnt, dodnt have any way of doing that Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
In that case a piece of wire with rag on bottom to soak up the oil, will have to suffice.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Take one of your old head bolts and cut some grooves lengthwise in it with and angle grinder and use it to clean the threads out. Lightly Oil your new bolts and under the heads of the new bolts and follow the full sequence as they’re Torque-to-Yield (TTY) bolts hence the degrees sequence on the td5.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 998 ![]() ![]() ![]() |
Or an air line and blow it out. Or… brake cleaner and spray it in there then forceps with a bit of rag to dab up the remains.
Good luck ![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
