Home > Td5 > head gasket or oil cooler, not sure wich |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
ok so took the head off ... have a look at the head gasket ... there are definigtely holes where there shouldn't be holes
Also, why use the corrrect dowels to hole the hesad on when you can use bits of HSS drill bits! Arghhh!!!! really surprised it was actually running A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
17th May 2023 11:00am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
Wow! Have you been running anti-freeze? That corrosion at the coolant jackets is bad for the period of time it has had the new gasket!
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
17th May 2023 11:40am |
Yup
Always use OAT antifreeze. have done with this beast since we purchased it in 2012 Part of me wonders if they changed the head gasket when they put the different head on. Long time ago 1 garage did the injector seals .. while trying to fix a bad starting issue I asked anothe grage ( within the last year) to change injector seals ... all the bolts holding the rocker shaft on sheared! At this point as i had a spare 10p engine in the garage ( as you do) 2nd garage replaced the head with the one from that engine. A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
17th May 2023 2:53pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4392 |
Holy Moses that gasket is appalling and an HSS drill bit? are you kidding?
17th May 2023 4:09pm |
Canb clearly see hss 8mm on one of them. The other one fell out of the head when I took the head off, was sitting on no 1 piston
So impressed the thing was runnig at all Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
17th May 2023 5:14pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 790 |
Demonstrates again, when you own a defender, learn and do as much of the work yourself. Unless you are really sure your garage is good, most just swap out simple parts.
17th May 2023 6:40pm |
