Home > Maintenance & Modifications > Bonnet pin
Drevil
2011 Defender 110 Puma 2.2 USW Indus Silver
Bonnet pin
Anyone know what size the lock nut on the bonnet pin on a Puma is?
Thanks
Post #992548 14th May 2023 9:00am
Do you mean spanner size or thread dimensions?
Post #992562 14th May 2023 11:03am
Drevil
Good question….spanner size.
Sits in between two of mine and would rather not buy 3 guessing the size.
Thanks
Post #992570 14th May 2023 11:53am
OK, I'll measure mine later for you.
Post #992576 14th May 2023 12:31pm
Dinnu
IIRC its 32mm 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992577 14th May 2023 12:36pm
Drevil
Thanks
Post #992593 14th May 2023 2:36pm
I've just measured mine and according to Mr Mitutoyo's finest it is 32.19mm AF. A 32mm spanner, or at a pinch a 1.1/4" AF spanner, should do the job.
Be aware that there are two different pins used on late Defenders as I found out the expensive way when mine needed replacing (the bonnet kept popping open whilst driving, which is disturbing). I think the nut is the same however.
Post #992609 14th May 2023 5:51pm
Drevil
Awesome thanks.
Remember the bonnet on one of my minis popping up on the motorway…..bit of a bum clencher!
Post #992612 14th May 2023 5:56pm
