Home > In Car Electronics > Aftermarket Amplifier In Standard Sound System - Help |
Furball Member Since: 31 Jan 2016 Location: Wiltshire Posts: 35 |
Hi Aaron, just to clarify, you want to install an amp and keep the standard speakers?
17th May 2023 2:35pm |
widger Member Since: 14 May 2023 Location: Adelaide Posts: 3 |
Hi mate,
Yes! I then will upgrade the speakers and sound deaden at a later date. Thanks Aaron. |
17th May 2023 2:39pm |
Its relatively easy. You need to make a decision on what spec speakers, then this will determine your amp or vice versa. They need to be ‘power matched’. If you need more info on this, then let me know. Do you have a spec in mind?
You can buy amps with both RCA connector inputs from your head unit, or take the speaker output from you system. If you are really struggling with your wiring, then i would go the latter route and use the speaker output and connect these to the amp then on to your new speakers. Potential issues; Baring in mind its a 2023 Defender and i assume having a invaluable warranty, i would be careful not to cut the wiring and use proper connectors. It may be worth seeking professional help as if you pay an approved audio centre, you will have recourse if it goes t1ts up. |
17th May 2023 5:06pm |
