Home > Maintenance & Modifications > Foxwing on SD Cage
bodstruck
Foxwing on SD Cage
Anyone mounted a foxwing or similar to a SD external cage? Looking for ideas please. I am expecting to do some fabrication but I need to be able to remove it.
Current thinking is to make use of the roof tent clamps I have lying around : https://shop.safetydevices.com/products/ro...ed-thread.
Thanks Thumbs Up
Post #991255 2nd May 2023 10:55pm
geobloke
It is not going to help you but I have my awning fixed to the underneath of the SD roof rack. Works a treat as it pushes the awning out enough to clear the curve of the roof.
If I were fixing to the tubes of the cage I would use the SD clamps as they really fix well to the tubes, whereas the roof tent ones are not designed to cope with something hanging off them. I would be concerned they would slip on the tubes.
https://shop.safetydevices.com/collections...ount-clamp
More expensive but solid.
Post #991304 3rd May 2023 12:57pm
bodstruck
Sorted now.
I picked up a JB roof tent (Facebook bargain, 700 notes and unused) so decided to work out something to mount them both on.
Used the SD clamps I had lying around (can't even remember where they came from), a recycled set of Van Guard roof bars, a commercial chopping board and a handful of stainless fasteners.
Post #994838 2nd Jun 2023 12:42pm
