Home > Maintenance & Modifications > Does this quote for paint etc sound expensive?
AMBxx
My 2015 110 XS SW is due some TLC.
I've been quoted for:
replacing windscreen frame
fitting SS mudflap brackets
respraying rear tub, cappings etc
rear cross member and NAS bumper back to bare metal, repaint
Dinitrol on underside
I'm confident that the work will be to a high standard.
Is £4.5K + VAT reasonable? It is planned to be a 'forever' vehicle, so the work does need doing.
Post #988693 12th Apr 2023 6:59am
kenzle8a
It depends, how does it break down?
Are they sourcing a new genuine window frame?
Are they taking the roof and sides off to re spray the cappings and the tub as a whole?
What level of prep do they go to for it? A rub down or back to bare metal?
if its a used window frame and a roof on blow over its expensive, if its new parts and a proper job its probably an indication of good workmanship.
Post #988696 12th Apr 2023 7:50am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
There is undoubtedly quite a lot of labour involved, particularly if they are doing a proper job and removing the roof and sides as lord-haggis suggests. That said, £4.5k + vat is steep IMO.
It might be worth tackling some of the jobs yourself if you are so inclined, others on here have written up their experience of undertaking most, if not all of the jobs you list. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #988697 12th Apr 2023 8:02am
AMBxx
It's down to bare metal with roof and sides off. New LR window frame. Very much belt and braces with cavity wax in the new frame and surrounding areas.
I'm limited to how much I can do myself - bending to work underneath a vehicle is a guarantee of a migraine and out for 2 days. I even have to be careful spraying underneath with a hose.
Post #988700 12th Apr 2023 9:05am
kenzle8a
Best way to be sure is always to get three quotes, painting varies so much between places based on exp, also if they know what they are doing with land rovers and the prep for alloy on the frame etc and it’s baked and cured in a proper booth as opposed to lamps etc then it all has a bearing.
Post #988712 12th Apr 2023 11:58am
Litch
Is the capping being removed?
Many moons ago I bought a brand-new rear tub (genuine LR) with the capping already fitted, tub was in grey primer and capping had some kind of black coating. Came from LR ready to go straight to the spray-shop.
Drilled out the rivets and the underside of the capping was almost completely devoid of paint with just the thinnest dusting covering the bare steel. No wonder the capping rotted out so quickly on painted models.
Needless to say they were galvanised before going back on to the freshly painted tub. ONE LIFE, GET IT!
Post #988734 12th Apr 2023 2:25pm
AMBxx
Yes, the capping is being removed and the lower half of the back being repainted due to that missing paint.
Post #988740 12th Apr 2023 3:01pm
JOW240725
That sounds expensive to me. A friend paid that sort of money for a change of colour full respray, inside and out.
I paid £600 for windscreen surround, rear cross memeber and B column one side and I think that included cutting down and respraying the bumperettes and fitting Bowler sills and new steps.
All you can do is get a couple of quotes and see. If you fancy a trip to sunny Suffolk I highly recommend speaking to Cult4x4. James
Instagram @suffolk_rovers
Post #988753 12th Apr 2023 5:27pm
