Home > Maintenance & Modifications > Front Wiper Motor - Sourcing Plug and Motor Hot
JackNorris
Hi all
Doing some work today on the 90 with the ignition on. When finished could smell a burning, Went around the cabin and eventually tracked it down to the Front Windscreen wiper motor.
The motor once exposed was ridiculously hot, given the wipers haven't been on, and I had to wait for it to cool to touch it.
I have tried to disconnect it at the park switch and everything but it seems everything is melted together.
Can anyone advise what plug I need so I can splice it back in? Its the 5 pin.
Also - Can I get away without having to expose wiper boxes to change motor?
Thanks
Post #986043 18th Mar 2023 9:20pm
rustandoil
The plug is available as a repair part, with six inches or so of the wires pre-installed....
Post #986066 19th Mar 2023 7:49am
Dinnu
Or could also get the connector with the terminals, and saves you splicing the wires.
I am unsure if this is the correct plug, but you get the idea:
https://www.ebay.com.au/itm/272203490313
But you would also need the correct crimping tool, such as this one:
https://www.amazon.co.uk/Connector-0-5-1-5...mp;sr=8-40 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #986070 19th Mar 2023 8:27am
