![]() | Home > Maintenance & Modifications > Tail gate to rear door coversion |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
They are weak with the spare wheel attached. I have half a safari door on my 90 and it's badly cracked around the top hinge.
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Thanks Martin...I'm hoping to get a Sonic/type carrier when I've 'refreshed' my savings (big bill elsewhere
![]() 2011 110 XS DC Stornoway Grey |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
I changed the drop down on my svx to side hinged, used the same door, it turned out a great job
also used mantec wheel carrier CR |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
So do I and it is in real need of a wheel carrier. |
Mark
PM sent ![]() Bob |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
I cut a Series safari door and managed to find piece of aluminum channel that fitted over the top. I used the standard hinges but did have a chassis mounted wheel carrier. It lasted the 5 years i had it.
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
A drop down tailgate is excellent for sitting on, changing boots after walking and brewing tea - why would you want to change it for a side opener? Makes sense if you could open it from inside, but if you've got a Sonic carrier then you'll have to get out to open that anyway. Peter
2008 SWB Truck Cab 1952 80" Soft top |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
I did this to mine a few years ago, makes the load bed a lot more useable.
here's the thread: http://www.defender2.net/forum/topic6699.html?highlight=tailgate Ben 2002 Defender 110 DC |
Thanks Yobbie, so the dimensions of the door were ok without any other mods?
MrFlips, I know what you're saying and fair point, but I use the space for carrying stuff an awful lot more than I use if for what you described.....the tailgate is useful for me occasionally, but I find myself cursing it more due to the 'stretch' to reach inside.....which will get even worse when the spare's moved aswell! That's sort of the point of my thread aswell, as I don't want to chop 'bit/s' off my perfect tailgate, then want to change back for any reason later on. Thanks Bob, replied to ![]() * also, thanks Ben...unfortunately the pics seem to have gone from that one. Mark 2011 110 XS DC Stornoway Grey |
I know its only a battered onld 90 but here is a couple of photos of how I chopped the rear door and capped it with some stainless steel.
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Any pics ? ![]() I want to make that mod, but I'm after all pics I can get my hand on ... just to make sure on what to do and don't do! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
