![]() | Home > Technical > Rear Wiper and Wash not working |
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 186 ![]() ![]() ![]() |
2007 Tdci. Both not working. Fuses are intact.
Front wash works ok. Done a search on previous posts. Trying to get my head round what would be the common failure given that they are on separate switches and the washer pump isn't in the rear door. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
The only common point is the fuse, which is the supply to the rear washer switch and to the rear door for the motor relay.
It's Fuse 10, 10 Amp. Check it again, take it out and re-seat it, or simply change it anyway (if no spare then swap for fuse 18 - left hand side lights). Check for voltage on it with a meter with the ignition switched on. ![]() ![]() |
Thanks Martin, I'll have another look.
