Home > General & Technical (L663) > Changing from built in nav to Google Maps
lightning
l've always used Google Maps as l prefer it, but this morning the Defender has defaulted to the built in navigation.
The phone is connected but l can't find out how to change it back to Google Maps. lt's done this before and there was a drop down menu if l recall to select it.
But this time l just can't find it. Can anyone help?
Post #985011 10th Mar 2023 11:32am
lightning
Also it looks like the vehicle's SIM card is no longer connected to the internet
l've checked in settings and it's turned on.
Post #985015 10th Mar 2023 11:54am
lightning
Solved it!
Reset the pivi pro (held down the power button for 20 seconds) and it's all come back, Google maps re appeared and the SIM is back online
Post #985018 10th Mar 2023 12:14pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Good you solved it. If it happens again, on the homescreen in the navigation window there's a button that if you tap it allows you to switch between carplay and built in for nav. https://instagram.com/bentheoandrews
Post #985020 10th Mar 2023 12:40pm
XplusYplusZ
Might be obvious, might not.. the quickest way I've found to switch nav source is:
1. Home Screen
2. Little nav source icon (red square)
3. Choose pivi or carplay
Post #985160 11th Mar 2023 4:46pm
lightning
That wouldn't work, l guess the system had crashed.
Post #985173 11th Mar 2023 6:17pm
XplusYplusZ
You don't see the option if your phone's not connected/doesn't have decent signal for google maps.
Post #986179 20th Mar 2023 1:58pm
