Home > Technical > Cam notch and flywheel not aligning |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
Yes as described.
8th Mar 2023 7:38pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
As above. Somehow a tooth out, how did that happen Make sure the chain guides and hydraulic tensioner are is good condition.
I fitted the AMC head on to Miffy the summer before last. Excellent quality |
8th Mar 2023 7:58pm |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 96 |
Thanks.
I've no idea how it happened. But there was a few signs of bad work from whoever did the job before. Excited to fit the AMC and have it done for good hopefully. Just to be sure, I should lock the flywheel in the slot and not the little dents, is this correct? |
8th Mar 2023 8:21pm |
