Home > General & Technical (L663) > Some help buying used please...
mcma1
After a looking around the showroom yesterday my wife has decided a used Defender 110 is ideal for her next, obviously I am encouraging this purchase!. Problem is I have no clue on the engines and spec we should be looking for within the budget £65k.
Used 110's are thin on the ground here in NI but this one below is available, with a BMW dealer I have bought from before. Only negative I can see from is it the lack of full leather. I think is was the LR demo but is it worth a look?
https://www.usedcarsni.com/2020-Land-Rover...p;sortby=6|0 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #984264 3rd Mar 2023 10:43am
XplusYplusZ
Not sure on the market in NI, but it looks pretty well specified.
I didn't see adaptive cruise control (which I find really useful for longer journeys).
Not wanting to fear monger, but for your information: The D240 engines did have some concerning issues upon launch and were quite quickly discontinued and moved from 4 cylinder D200/D240 to 6 cylinder D250/D300s. I read various stories about the issue, but I understood that the DPF may have been part of the issue, so be careful if this is primarily for shorter journeys.
Of course, give LR a shout and see if you can get extended warranty for your ownership timeframe. I'm not sure I'd feel comfortable without some form of warranty coverage on any vehicle of this value.
Post #984268 3rd Mar 2023 11:25am
The most obvious thing is that it's an earlier and less desirable 2.0l 4 pot rather than the later 3.0l 6 and the badge suggests that it's an SE.
The description is somewhat hilarious as it declares that it is LESS roof rack or rails, despite them being clearly visible, and that it has a body coloured roof, which isn't Rolling Eyes Darren
Post #984269 3rd Mar 2023 11:27am
mcma1
Thanks, Very useful info on the D240 engine. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #984270 3rd Mar 2023 11:28am
mcma1
Its a BMW dealer trying to sell something they don't know much about to be fair but a very good dealership here.
Glad I asked to get the info on the engines though Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #984274 3rd Mar 2023 11:31am
mcma1
Maybe track down something like this? It will be used daily on short runs.
https://used.landrover.co.uk/approved-used...6?___SID=U Andy
2014 Corris 110 SW
LS3 V8 build...
Post #984276 3rd Mar 2023 11:40am
I understand what you're saying but the two things I picked out are so blindingly obvious that it's clear that somebody wasn't paying attention. Whilst mildly amusing on their own, I'd be asking myself if they'd messed up on anything else and reviewing the rest of the spec carefully to make sure it's as expected. Just from reading posts on here, it's clear that LR options are a minefield, unfortunately. Darren
Post #984277 3rd Mar 2023 11:47am
XplusYplusZ
The options are definitely very much a minefield. In 2022 we've seen MY22, MY23 and MY23.5 models delivered due to the supply chain issues.
Take a look at the fabric sections of the seats - it was also a bit of a problem for earlier models during launch, as the fabric they used was pretty prone to water staining. Something a good steam clean could probably resolve, but likely will come back without some form of fabric protection treatment. Plenty of threads around on this topic.
They subsequently moved to a 'ROBUSTEC' fabric (which has little pleather dots in the pattern) which is an improvement on the older fabrics. It looks like this add has the older - more stain prone fabric.
On the plus side, the older models had better base specs. I see this model has an interactive drivers display - not guaranteed nowadays but desirable, and the 'clear sight' video mirror - pretty rare in today's specs. Even air suspension has been cut from the base specs for MY23.5 So there are some advantages to the older models.
I would recommend looking around for an early D250 - which seems to have had less issues and a more robust 3.0l engine (the block is being used in models between 250hp up to 350hp in the new RRs so probably a little over built/under utilised in D250 guise). OR at least use this as a bargaining tool to get a bit of money off.
Post #984281 3rd Mar 2023 12:24pm
Co1
I assume you’ll be ripping the diesel lump out and sticking another LS3 in?!’
Post #984298 3rd Mar 2023 4:16pm
mcma1
Post #984301 3rd Mar 2023 4:27pm
Tim in Scotland
I’ve been running a D240 First Edition 110 since June 2020 and mechanically it has not had any issues whereas I’m about to take delivery of a D250 where there have been some well documented issues with belt tensioner brackets and chaffing on air intake hoses. My D240 now got 21000 miles on it and has had additional oil/filter changes at 11000 miles/ 12 months as well as the LR scheduled 21000 miles/ 2 years. i have used how it was intended to be used and had it Clear Gloss wrapped very early in its life to protect the paint. It’s been one of the best LR products I’ve owned, 2C problems apart!
Where I have had issues with mine has been to do with dire quality control at the factory - it’s been back to the workshop 15 times for rattles and rainwater leaks into the cabin through the rear offside door trim and around the windscreen. I also had the rear screen washer line come adrift inside the A Pillar trim filling the driver’s footwell with screen wash water.
If you can find one then there was a short period of production of D250 First Editions and they are quite rare but still have all the no-cost extras on them that now many are discontinued or optional. Pre 2022 110’s should have air suspension as standard, coils were an option at no cost thought.
Even rarer if you want it is to find a D240 with the rear ediff. First Editions were very popular as they were good value for money and LR stopped making them after the 1st 12 months of sales but then produced an XS model with almost all the toys of the First Edition but also the restricted colour choice and they added body coloured lower trims which aren’t to everyone’s taste and look better in some of the colour ways than others. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #984388 4th Mar 2023 5:53pm
mcma1
Thanks for the info.
After some testing she now feels the 90 is plenty and likes this one. Ideally we would want a Carpathian grey d250 with vintage tan but more chance winning the lotto tonight than finding a used one.
https://urldefense.com/v3/__https:/www.aut...4jx4iDtcg$ Andy
2014 Corris 110 SW
LS3 V8 build...
Post #984390 4th Mar 2023 6:11pm
Tim in Scotland
That is more expensive than the 90 D250 HSE with a heap of extras I have coming from the factory to my local dealers next week ……… Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #984402 4th Mar 2023 8:17pm
mcma1
How long have you waited for delivery? What do you think that one is worth? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #984405 4th Mar 2023 8:31pm
Tim in Scotland
9 months wait reduced from 18 when I ordered last May, but I already have a 2020 110 that it will replace so i wasn’t in a hurry for delivery either. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #984412 4th Mar 2023 10:22pm
