![]() | Home > Puma (Tdci) > Help an idiot with oil seal direction |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506 ![]() ![]() |
Wise ones
Just changing the rear hub oil seals and my new seal is stamped with one side towards stub axle. Am I right in thinking that this side faces out front the rear of the hub towards the centre of the car? What I should have done was check the old one before I yanked it out, but that sort of thing is for sensible people Thanks Wes Oh woe, oh woe My crusty old landrover, It will not go. |
Yes that is right, towards the prop shaft
![]() Edit: Should look like this ![]() Click image to enlarge |
Legend, thank you sir.
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
That is a great way of showing the direction of the seal!
As for checking the old one first, one of mine was the wrong way around!
Why thank you sir ![]() ![]() On seals like this one that have a hollow internal half and a sticky-outy half the hollow half always goes towards the greasy bearings and the sticky-outy half to the outside towards the elements. |
I have no idea, but I wouldn't use it. Looks almost like it has been welded and ground down again.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17918 ![]() ![]() ![]() |
And there I was thinking it was a brand new B***part stub axle!
Only kidding. ![]() |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
Make sure you change the stub axle seal whilst its apart
Yeah, as it goes that was the one that was actually leaking...badly.
I'm not sure my driveway will ever recover from this ecological disater Oh woe, oh woe My crusty old landrover, It will not go. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1305 ![]() ![]() ![]() |
It won't because soon something else will be leaking
